1979 RD400 Wont fire
dirtbag
Ok here's the story.
1979 RD400 daytona. Has CDI ignition
I swapped motors out for another. Put same carbs on as the other motor. I tested the resistance on the charging circuit and it all checks out. It just wont fire. Plugs are wet.
Left compression is 100psi
Right is 125 psi
I havent checked the timing which im hoping is it. Am I going to damage this motor by flooding? Why wont it catch spark? Any other things to try?
I'm using BR8ES plugs.
Are you getting spark at the plugs? Take them out, plug one into the lead, ground the plug body on the head and kick the motor. If you're getting spark, you might have the coils the "wrong" way. Change the plug leads over and see if it fires.
Checkconnectors from motor, check you didn't trap wiring under sprocket cover
If you have spark and it wont fire, check you have carb slides in correct carbs.
They fit in 'wrong sides' but don't close
you do have same generator on both motors?
I think they used Hitachi and Denso but I don't remember details from 31 yrs ago
You know the motor you fitted is good? (you saw it running?)
I don't know anything about the motor I fitted. It should pop at least. I"ll double check the slides (they went in nice but may be backwards?) I ordrered a dial gauge so while waiting I may just re-ring it.
I think the crank seal is fine. I left the reeds on the engine of the junker bike. I may swap out the reeds from the working bike.
Got all the old gas outta the crankcase. Put new plugs in. Fired first kick.
IT LIVES!!!!!!!!!!! Now how do I make it smoke less?
Nice work ;)
You'll probably need to take it for a bit of a run to get all the old oil out of the crankcase / pipes / etc. After that, if it's still smoking "excessively" you might need to adjust the oil pump as per the manual specs.
I'm not a stroker expert so I can't tell you any more :-\
Tomorrow i'll sync the carbs and then adjust the oil pump. Makes good power, the front wheel came up in first on my rip down the street.
