1980 cb 125 cam chain tensioner noise?
ticking noise near the head. i did two tappet adjustments and it was still there. all i could really find in any manuals and online is to adjust the cam chain tension. when i unscrewed the lock nut for the adjustment nothing happened. the adjustment screw was all the way down anyways. i ended up completely taking out the lock nut portion and could push down on the cam chain adjuster and loosen it while it was running, so the mechanism itself works. i took the top end off and unscrewed the tensioner at the top near the head and the cam chain adjuster came all the way to the top of the hole, much closer to where i think it should be, for the adjustment screw to be effective anyways. is it possible that my cam chain is too short? where should the adjuster naturally sit relative to the top of the adjustment screw hole? is there another adjustment at the bottom of the chain tensioner? like the bottom where its connected? i'm sorry if i'm not being clear here. any information would be helpful.
