1980 CB650: Jersey Devil Project
walnuts
First off, let me explain the title. I bought this bike from a guy in Central NJ and it had a stuffed Taz (the Tazmanian Devil cartoon character) zip tied to the rear end so I figured it was as a good a name as any. When the bike is "finished" I'll come up with a proper name for it.
This will be only the second bike I've ever owned and the first I've modified. My goal for this is to be a learning experience if nothing else but if everything works out I'll have a second bike in the garage so my bikeless friends can come over and ride with me.
I've attached a "before" picture of the bike. As you can see the PO really tried to make it as tacky as possible. All the body panels have been repainted with what appears to be truck bed liner, every exposed nut was replaced with a plastic skull including the valve stem caps, no less than 15 other skulls were taped or glued on in random places, it has those lovely leather tassles on the handles, "custom" diamond plate side panels, and lets not forget the two deer whistles mounted to the front fender (ok, so based on where he lived I can kinda see how that was useful), etc. All-in-all though it appears to be a pretty solid starting point and it so far I'm only into it the cost of a few spare car parts I had laying around to sell. It was running when I went to look at it but sounds like it needs a valve adjustment from the ticking/tapping sounds it was making.
So far all I've done is take some of the tacky crap off, pull and charge the battery, and buy a set of feeler gauges that I'll need to attempt a valve adjustment but as we all do, I've got plans!
First things first, I'm going to get the engine running smoothly. Hopefully that only requires some adjustments etc but if I have to do a complete tear-down, so be it. After that, the real fun will ensue. So far I plan on keeping the front end and rear swing arm though I might drop the front about an inch or see if I can find a set of forks from a CB550 or 750 that could accomplish the same thing and will definitely be putting longer rear shocks on to roll the chassis forward to decrease the rake and trail as well as creating a more comfortable riding position and seat height. Eventually I might replace the front end with a new set of forks but I'm trying to stay somewhat period with the components I want to use. For now the biggest change will be switching to a drag bar or other lower bar so the riding position will be closer to what I've got on my Buell Lightning. I'm not sure if I want to go with clubmans or clipons yet as I'm not positive I'll be comfortable in such a forward leaning position. Eventually the foot controls will get replaced with rear sets but for now I'll keep the stock components for the ease of it.
The frame is going to get stripped and blasted back to bare metal. All of the tabs and brackets that will not be needed will get cut off, any areas that look to have been stitch welded at the factory will get ground and seam welded, gusset plates will be welded into all of the corners as well as a few extra bits of tubing to stiffen/strengthen things up. I am still trying to figure out what, if anything, to do about the dip in the frame rail below the seat. I've seen some bikes where that has been incorporated into the shape of the seat and it looks really nice but I keep thinking how nice it would be to have a clean straight line down the side (aesthetics, I know).
The entire bike is going to get rewired as some of the current wiring is iffy (for some reason the left turn signal switch makes the tail light blink) and I'd like to upgrade the lighting, controls, and electrical system anyways. I'd like to mount a modern LED dash display and use LED lighting for the signal lights too. The headlight will get lowered and maybe replaced.
I know this is probably all coming across as the typical newb post and that's because I am a newb with big dreams of what my bike could be but I'm not under any dilusions that this will be an easy or fast process. Hell, I'm just praying I don't end up two years from now taking a truck load of bike parts to the scrap yard! So wish me luck (if you will) and please feel free to comment. I'd prefer constructive criticism, but hey, its the internet so I'll take what I can get.
Well, I started taking some stuff off of the bike this weekend, nothing huge yet. Rear marker lights and fender assembly, seat, that weird grab bar, and the crappy pod filters. After the filters came off I realized that the carbs are currently sprung in the "wide open" position and do not respond to twisting the throttle at all so it looks like I'll be pulling them for a rebuild and replacing the throttle cables before I can try to fire it up again. Oh well, I'd planned on doing that eventually so it just changes the order of stuff. I'll drain the oil, change the filter, and put fresh in as a precaution. That will all get drained, refilled, and changed again after it is running.
In the mean time, next time I get a bit of time to work on it (hopefully more than 15 minutes) I'll start pulling crap that I don't want to reuse from the front end, get the tank drained and removed so it can be cleaned, stripped, get the one little hole on the side welded up, and painted with some rattle can stuff from the auto parts store to start seeing how the bike will look when it is finished plus protect it from rust. Eventually, that too will get stripped off and some quality paint applied.
I'm looking to replace the front end with something from a CBR, mid '90s to mid '00s with non-inverted forks so I can get the benefits of newer suspension and possibly dual brakes but with a more classic look. Also trying to find some good CB series hubs to use for spoked wheels.
Can anyone tell me why I wouldn't want to use a front hub on the rear wheel so I can switch from drum to disc brake? I know I'll lose the cush drive but how detrimental will that really be? Any suggestions for a source to get a cush drive rear hub that was originally made for a disc brake?
Yep... so I completely forgot I had started this thread. Here's a photo or two of the progress I've made so far.
I've pretty well stripped the frame down, removed all the tabs and such that I'm not going to need, cut off the center stand though I'm not entirely sure what possessed me to do that. I've had one hole in the side of the fuel tank welded shut and have one more that needs to be sealed up yet. The rust you see in the picture is just surface rust and will be taken care of shortly. I dropped the frame off at a local shop to get the seat rails modified to be flat, similar to the frame of a '79 CB650.
The engine ran pretty well when I first bought it and I realize now that the top end and the carbs had been replaced with those from an '81-'82 which I believe will be easier to work with in the future. On the engine itself, I've mostly just done cosmetic stuff and clean-up work. Once I get everything back together and running I'll decide if I want/need to to a complete overhaul on it as well. Aside from the stripping and painting of some of the covers (still need to do the oil filter cover, oil pan, and clutch cover) I decided to polish the edges of a few of the upper cooling fins and replace all of the externally visible hardware with 316 Stainless Steel socket head cap screws and aluminum sealing washers (where necessary).
Progress has been very slow as I'm still learning a lot about what I need to do and how to do it as well as not having much free time.
Augh... I just looked at the before picture in my first post again. I can't believe how crap-tastic this thing was!
