Vintagepeej
1980 Honda CM400
Hello!
First time poster, long time reader.
I own a fixer-upper CM400, but I love it. It is such a simple bike to work on and has such a great vibe. Anywho, on to the business:
The bad:
- When we first picked it up, it didn't start. (A simple matter of a blown fuse).
- The left side side cover fell off during a test drive and was promptly run over by a car. (Completely crushed my spirits that day).
- The carburetors were all gummed up as with any old bike that's been sitting awhile. (I cleaned them, but they still had a leak coming from the overflow lines so I ordered some float needles to see if that would fix the problem and I'm still waiting for them to arrive.)
The good:
- Runs strong
- Good tires
- Clean bike that hasn't been modded before. (Clean template)
So I suppose my first question is a carb question... has anyone else had this same problem where the gasoline will pour out of the overflow? How did you fix it? I've completely taken it apart, cleaned it, put in new gaskets and o-rings and put it back together. When it still leaked I thought the only problem could be the float needles or the floats themselves. Since the floats were good and had no pinholes, I decided to just order the needles.
Thanks for reading and in advance for any advice/wisdom! ;D
The bad:
The good:
- Runs strong
- Good tires
