The Lunch Journals
Edit: I've decided to abandon the idea. Everyone who chimed here, in other forums, and a friend who's helping me are absolutely right: It's more trouble than it's worth. Not to mention the money wasted! But thanks for the input regardless!
Currently in the process of converting a CM400T to a cafe/bobber/racer/somethingorother and I had the idea of using all that newly freed up space under the seat (where the airbox used to be) to install a small turbo. Not for any practical reason other than to have a turbocharged bike.
I planned on using the draw or suck-through setup by having the turbo between the heads and the soon-to-be-procured single, larger, carb.
The only snag I have come across is an oil supply for the turbo itself. Any recommendation on how to plumb the lines? Or where? Should I assume I'm going to need a separate pump?
Also open to suggestions on types of turbos to use. Ecotrons.com seems to make a small one [along with pump] that might work nicely but I have no problems going with a used solution either. I told myself I'm going to try and keep parts costs to under $1500 over the course of time I mess around with this.
Thanks!
Thanks!
