sbruton
Where the fvck is that money you owe me?!?
Hi all,
I am seeking suggestions on trouble shooting a problem I've got getting a 1980 SR 250 to fire up. I acquired this bike a couple of weeks ago with the hope of getting it running and then flip it to help fund my current project. My intention is to clean it up, fix the obvious problems, replace some parts with spares I have in my garage and then sell it to someone looking for a winter project. Seems simple enough right? Wrong. I've run into a jam with getting it started that I hope someone can help narrow my search:
In short, the problem is this... The bike rolls over well, has good spark yet will not fire and run. If I squirt a few mL of gas into the cylinder it will fire up idle and run well. In fact I had it running well enough on the weekend that I took it for a spin around the neighbourhood. However, after turning it off and letting it sit for a couple of days it will not fire up again without squirting fuel into the cylinder.
To date I have completed the following:
1.) removed the carb, removed all the jets and gave all the passages a thorough cleaning with carb cleaner
2.) confirmed spark at the plug with 2 different spark plugs
3.) confirmed that fuel is getting into the carb from the tank and that the petcock is not plugged
4.) replaced the intake manifold and gasket on the cylinder
5.) adjusted A/F mixture but not too sure what the stock setting is?? currently at 1.5 turns out.
I plan to pull the carb off and take it apart again tonight, but if there are any suggestions of particular items to check it would be really appreciated. Based on above I'm assuming I still have a blocked passage or a vacuum issue but I'm only guessing....
Any ideas or help would be greatly appreciated!
Thanks in advance!
Thanks in advance!
