I woke up today to 63 degree weather, so I quickly drank my coffee and went to the garage in excitement to lay down some clear coat on the swing arm. I painted all my pieces including the frame around halloween and have been waiting for a break in the weather like today to get the clear coat down. A couple of weeks after I finished the paint, my swing arm fell down in the garage on the bare concrete. My first inspection, I noticed that a there was a little chip on the chain guard mount, but hadn't seen anything else. When I went down today, I realized it was worse then when I first looked at it. There's a dime-sized chip towards the top. I know it fell on concrete, but COOOMMMMEEE ON MAN! I checked the spot to see if it could chip even more. It wasn't super easy, but it does chip some more with a little effort. Did I do something wrong here? I would think that this paint should be much stronger and it should be cured by now. This all has been just sitting in my garage for a month plus now.
So, I could use a little advice from all the expert painters out there. How I painted:
Stripped the frame
Knocked off as much rust as possible
2-3 coats of Self Etching Primer
2 coats of Primer Sealer
4-5 coats of Dupli-Color Engine Enamel Gloss Black paint
I did follow the instructions on the can.
Will the clear coat make it that much stronger, or is there something I can use to add strength? I did use cans because of my situation. I don't have a gun, and powder coating is looking to be too expensive (I got a quote today that it would cost me around $300). I'm doing my best to spend reasonable money right now, because that's all I have. I asked a similar question earlier and received a response from chambers recommending 2pak. I looked into it and it's around $25. If I'm going to invest anymore money in freaking cans, they better freaking work.
I'll take any advice right now. I want to do this right. Maybe I just suck at painting. Maybe I'm using the wrong stuff. Maybe I held the can too close or far away. Maybe this crap isn't curing correctly because it's in my garage. Not sure if this is helpful, but I was also having a hell of a time not getting spit from the can all over whatever I was painting. It was impossible to get a nice, even, clean coat. This has been the most frustrating, irritating, pain in the ass ever! So if you have any advice, or can point me to another thread about this sort of thing, I'd really, really appreciate it.
Sorry for the long post, I'm just trying to figure this whole thing out.
