1981 CB750 C indicator help
Remington
Hi DTT world. I'm replacing both the front and back stock indicators and brake light (see pictures) on my 1981 CB750 C with a more custom set up. The rear will simply be two red bullet lights (see pictures) that function as the brake light when I brake and when I indicate a turn, I want the corresponding side to start to flash as the indicator. All indicators should be running lights.
I haven't started wiring the rear because I don't even know where to start. I've included a picture of what connected to the original brake/indicator setup and it doesn't match what I have available for the new bullets (three wire connection) so your input would be appreciated there!
As for the front, I basically connected the new wires to where the old ones were and the indicators turn on but don't blink when I flip the switch. I didn't think I needed to do anything special because the new indicators are dual filament and not led's.. but obviously not working.
Description of new parts:
New rear indicators/Brake lights: K&S Black Aluminum 47mm Bullet Turn Signals - Red Lens - Dual Filament
New front indicators: K&S Technologies Black Satin Aluminum Marker Lights - Round #3 with Smoke Lens - Dual Filament 25-8631
Assuming you're using running lights on the front, those get connected to the and and blue wires with the white stripe while the turn signal wires get connected to the orange and blue wires without the white stripe.
The rear is going to be more complicated if you want to use then as running, brake, and turn signals. The easiest way is to get a three into two trailer light adapter, but it can also be done with a pair of double pole, double throw automotive relays.
Thanks Sonreir, the 3 into 2 trailer adapter seems like a viable option. I'm curious though, there are three wires coming from each rear indicator and only one wire coming from the adapter for either direction. How do you go about wiring each side together?
This is the one you want:
http://www.etrailer.com/Wiring/Tow-Ready/119130.html
Both lights will share the tail light wire, but then the right and left each get their own turn/brake wire.
