1981 CM400 timing. I need some clarification !
Drey6
Over 1,000 Posts
Timing this bike is terrifying. I'm trying to single a few things out. How much power should I have at the spark plugs when I attempt to start the bike? And any other places to test that anyone can reccomend would be fantastic!
Thanks
if your reading the haynes manual they have it completely reversed. not the process but the actual timing.
Not exactly sure? I need to know correctly how to check for spark and also from there a checklist of things to check for as far as timing goes. Sorry if I sound needy, I'm just knocking on the door of completion and I am going insane with this. Haha
take ONE spark plug out and leave it connected to the spark plug cap.
have the end of the plug touching the engine, this is grounding it. <--- important
try to kick/start the bike and you should see a spark.
if you dont see a blue arc (spark)...
I bet the kill switch is grounded out.
check for continuity of ground with the switch in the run position.
if there is continuity to ground in the run position the cdi unit is grounded and will not spark.
Not sure what you mean, I thought the CM had CDI and no timing was necessary. Unless the woodruff key shears off or the CDI unit is toast, the timing should be good.
+ 1 to Deacon, There is no ignition timing to change on the bike. There is valve timing and that has to be set if you cracked the motor, if not that will be fine too. CDI and pick ups on the stator/rotor set ignition timing automatically. Oh and if you are turning the bike over by hand do not turn it backwards, the cam chain can slip and your valve timing will go out and you can really break things. I turned my 81 over backwards once and luckily noticed the cam chain slip and got it back in place before trying to start it again, could have been a disaster of pistons hitting valves.
Should have mentioned this before but I did remove the head to replace the head gasket. Let me know what this changes. I will have some time to try a few things here in a couple of hours. I should also mention that the bike ran before I began the tear down.
OK, so you removed the cam etc, You need to make sure the cam sprocket is bolted on correctly, which I think it can only go on one way, then make sure that your timing marks all line up with the the piston at TDC On the compression stroke, (this is from a foggy mememory exact specs are in your manual) If that is correct your valves should be opening and closing at the correct times, if it won't run check to make sure you are not 180 deg out on valve timing, valves won't hit pistons but the wrong valves open on the cycles/strokes, exhaust on intake cycle and intake on exhaust cycle and you are going to spark at the wrong time. also will never suck fuel in right either. Suck, Squish, bang, blow.
Also want to check the cam went in right, if it is backward the lobs will not hit the correct valves. I can't rememeber if you can put the cam in backwards or not on that motor. I do have a head and cam I can look at when I get home and see.
There is no difference between exhaust/compression and intake/power strokes until the cam is installed. TDC is TDC.
Maritime: I know the cam is back in the correct position since I followed the manuals instructions to a "T" when reinstalling that. I also made a point to match it up with the flywheel at TDC, just as the manual instructed. I have not made the mistake of turning the flywheel the opposite direction so I believe I am good there.
Sonrier: I have been thinking the same way about this. TDC should be TDC.
rlhphotos: I have not tested the coil but I couldn't see how that could be bad if it ran fine before removing it, I don't see why that would change. With that said though I will check that as well while I'm at it
First and foremost I need to check for spark. Also when I do attempt to fire it if I get a spark and the coil checks out, what position should the flywheel be in? At "T"?
On the flywheel I have "T", "F" and two "ll" (advance marks). Can to explain what "LF" is?
Drey6 I think, but it has been a while now since I have played with this motor, sold the bike a year ago. But there are 2 brass circles on the flywheel that go under the pickup on the case and I think it fires once for each if those, left then right, not sure if they are marked. To test fro spark you can just pull the plugs and ground one on the engine, hit the start button and see if it sparks when the motor turns over, if it does, you issue is likely fueling as the bike will only fire correctly with the CDI, no adjusting of ignition timing is available. I do know the CDI needs to be grounded by the mounting bolts and so no paint in the threads is important and also I think there is a ground point and wire near that needs to be nice and clean.
Maritime: I'm going to have to check my grounds as I did paint the block so that may be part of it.
My friend is going to swing by to give me a hand around 5 EST so that may help since he has rebuilt a few engines. I'd love to hear her start before I leave tonight to head to Chicago to see Pearl Jam play tomorrow. It would really make my vacation more enjoyable. It would keep me from thinking about how I can't get my bike to start!
Sorry... got mixed up. "LF" only applies to bikes with points. You're on CDI.
No worries, I just read that and was like fuck, more I don't know and/ or understand. Haha. thanks for the help so far everyone!
Good luck and enjoy the Pearl Jam show, I saw them about 5 years ago and it was a wicked show. They played for almost 3 hours because the crowd was really great and buying Eddy good Canadian beer, he was a little tipsy by the end of the las encore.
