1981 Suzuki GS450 Uni Pod size?
BiellaBound
Active Member
Hey guys I already know the issues with Pods on the GS, I don't want the performance but just to clean up the giant Air Box so I can put a small tool roll behind the side cover. . I am planning on putting a rolled aluminum can inside the pod to restrict airflow to avoid re-jetting. I read about that on DTT.
What size Uni Pod diameter fits the GS 450?
Thanks guys, I've been searching and just can't find the answer.
54mm
but why didnt you just measure one of the inlets?
by the way you have mikuni bs34 carbs
By the time you've mucked around with that a bunch of times to get it right you could have changed the jets a bunch of times. No airbox means the carbs are off in seconds.
And I'm pretty sure I used 52mm ones on my 450 because it was more secure to "spread" them over the carb ends than to clamp down the 54's. Either ones will work.
You're right I may run it that way to get it to the shop or I can have them properly re jet.
Thanks for the information very much appreciated
