Re: 1982 CB750F Resto-mod. At least that's the current plan.
Things are on the up. Pulled the tank and checked all the hoses, possible that the vacuum hose was a bit pinched, I’m not sure. Everything else looked kosher, nothing binding but I gave everything a good check.
Drained float bowl in carb 1, took the bowl off - everything looked alright in there but I pulled the float and needle anyway and gave them both a good clean, also blasted carb cleaner up into the needle seat. As Irk suggested I also blew through the fuel line.
Hooked the tank up again, carb 1 leaked right away but once I fired up the engine it stopped and didn’t leak again. Bike’s idling better, revs aren’t going up by themselves like before - a little stuttery when I crack the throttle and release it (as the revs drop they don’t do so smoothly but a bit juddery). Here’s a vid -
https://youtu.be/oiVI40OEzDc
Definite improvement
