Worked on the brake calipers yesterday, man they're crusty. Thankfully I now have a small air compressor in the garage so getting the pistons out wasn't too much trouble, but one did need some encouragement from some pliers to get it past the roached seals. The piston is slightly scratched and I'm pretty sure I can clean it up with some fine grit sandpaper and some Autosol metal polish. Is that cool? I'll be careful no to remove any material from the piston - just the scratch.
The seal grooves inside each caliper are in pretty rough shape too, and the seals were all completely destroyed (whoever rode this beast last must have had zero heel left on their boots - I think that must've been the only way they got this thing to slow down). I used mechanic's picks to remove all the crud in there, and will let them sit in some clean brake fluid for a while too. Is there anything else I can/should do to get these thing clean before rebuilding them?
The rear brake master cylinder however was in the worst shape. The thing just looks awful - all the seals are toast and it's covered in crystallized brake fluid. Once I got the boot off to dig out the circlip, it looked full of rust and the circlip ain't budging for love or money - in fact it shattered my circlip pliers trying to remove it. Any ideas on how I can get that thing out? Tried soaking it in PB Blaster to - so far - no avail.
