There is a great CB750 carb rebuild procedure pdf by SeanG on cb750c.com: http://www.cb750c.com/publicdocs/SeanG/Honda_Carb_Manual_revG.pdf (don't know if a direct link works, but you can try). It stresses thorough cleaning of the slow speed jets and pilot circuit. My accelerator jets were plugged solid, eve with sonication and carb cleaner under pressure. I ended up with the finest guitar string I had (high G from a 12 string) in a pin vice to reach from the outlet end with butterfly open and finally hit the tiny hole to clear it, then a liberal flush of carb cleaner. But, mine had been sitting since 1999. I also had to solder up two of my overflow tubes due to cracks. I made a temp fuel supply with 91% isopropyl alcohol for leak testing. Less stink, evaporates well, mixes and burns if any is left. To test for cracked overflow tubes, fill each with alcohol over a sink with the bowl drain closed. Nothing should come out the drain. If it does, inspect carefully for a crack running up the tube. I soldered mine.
