1982 KZ750H Build
slc-kz
Picked up a healthy but somewhat boring KZ750H in the spring and made some small modifications to it to enjoy throughout the summer. I had some issues with carbs (probably float stick) so it's come inside for the winter to get completely reworked
14DYi4cGX4njiFk3
I've started with a full seat hoop re-work to fix the "broken back" look 750H's have sadly shown they have and fork conversion (06-08 GSX-R). Thanks to the guys over at Cognito Moto I should be getting the forks fully installed this weekend. Overall the project is going to be a mesh of new and old. The front will be a 17x2.15 or 2.75. I'll be leaving the rear classic style suspension and maybe up sizing the rear wheel to Accommodate a 17x4.25 if the chain and frame will allow for it if not I may stay with a 3" rear. Also planning on a full top-end rebuild, custom exhaust, keihin CR29 race carbs and a lot more. Here's some photos of my early frame progress. I'm sure i'll be getting plenty of questions out as I go.
8oik7XKZ1HpPvg00
LTgDh3tsNIq7qxxp
1KgrQPITejYhbx6o
You lost at least 3 inches of tire clearance. Your back tire is going to slam into the subframe on the smallest of bumps. Do it again.
Yup, you need a hoop the kicks up in the rear at least.
Sent from my VS985 4G using Tapatalk
Thanks for the input. We'll actually be bringing the back up quite a bit from where it is in the photo. That's the stock 12.75ish rear shocks just for seeing how it sat once it was on the ground and we haven't put the new forks on yet. We knew the rear just above the tire may be problematic and may kick it up. Also after looking into clearances we'll probably be running with a larger rim size front and rear wheel for ground clearance since we'll be losing some more with the new front forks.
I'm looking at some options for rear shocks that allow 14-1/4, 14.35 to a full 15 inches in the rear so I feel like i'll definitely be able to get the clearance in the rear. Based on the 2+ inch drop shocks that were on it I believe this shouldn't be a problem correct?
No, shocks that are almost 2 inches over stock are not a good idea. The way to fix this issue is to build the subframe correctly.
The shock mount points haven't changed at all on the build. I do completely understand an upturned rear suggested previously, but completely reworking everything already done isn't changing anything in regard to actual suspension geometry as the rear shock points are unchanged from stock. Riding position has in whole.
You clearly do not understand. I said nothing about shock mount points. See that brace you cut out at the rear of the subframe? See how its a virtual trapezoid that rises 2 inches above the highest part of the stock frame and doesn't go straight across from subframe rail to subframe rail? That's because the tire would hit it if it did. You need to rebuild the rear of the subframe or it's wrong.
In addition to that mistake, you cut the shock mount gusset at a different angle so you could lay your new framerails in more parrallel to the ground than the original framerails were, which further limits your clearance.
You are obviously aware of these mistakes because your plan was to use longer shocks for more clearance which will give the bike less rake and trail which will make it handle like a turd. Also it looks as though you might have ground some of the welds on the shock mount gussets. I hope not.
Good thing there are resources like this to get those issues tackled early eh? Bikes are for riding not for sitting in front of a train with graffitti on it for a filtered photo shoot.
I do understand what you're saying and it was a concern when we went to modifying. That being said the angle in exactly level to the starting point we raised the front of the seat tube to in the front. Would applying a bend to the portion behind the "trapezoid" that rises 2 inches above the current plum flat portion resolve the tire clearance issue you're concerned about. Also, considering large scale front end and rear end changes are going to happen we know things will be changing throughout the project. I understand having an opinion on a potential issue but saying something is simply "wrong" is like me saying the original riding position was "wrong" for the riding I do. Isn't the take on a "custom" project partially learning what works and partially learning how to do things to your personal and aesthetic wants and needs? This is a first time major project and one that will take time, work and learning, it might be helpful to state recommendations rather than "wrong" and "do it over". Sorry to be offensive if I am, this is a learning process for me as for many people that came before me and one I thought I might be able to get assistance and productive help from here. If not, maybe this isn't the best place for me to post until I get things "right"
Doesn't learning include seriously considering the advice of those who have already done what are doing dozens of times?
It's built wrong. This ridiculous brat trend must end before every good bike is worthless.
A brat is what you build when you don't know how to build a bike.
Please explain the benefits of a gsxr frontend on a kz750.
Did you know that kz frames are not very strong? Did you know that USD frontends exert a lot more force on a frame? How do you plan to address this?
Why do you have your forks dropped 4 inches through the triples in that pic? Do you plan on lowering the frontend to a completely unusable height? Do you know that vintage japanese bikes have very wide cranks and require a certain amount of ride height to keep the engine from crashing into the ground and leaving you wadded up in a ball on the side of the road?
Hey listen,
I'm not saying I'm ignoring what you're saying and your opinion of what you've done dozens of times and I have been considering opinions of a lot of people through the current process including the work already done. What I'm asking is why your opinions (frame trapezoid-ness aside - which I knew may be an issue) are what they are so I can learn. It's like learning from a test that just has x's and no reasoning. In the case of this bike it was 2+ inches LOWER when I got it and rode not-badly. Why (in your opinion) would bringing the rear up be a terrible idea when the front geometry is also changing drastically? Again, I'm not saying you're wrong in your advice, it's valued. Seriously.
Hey listen? You need to learn how to talk to people.
I'm talking about motorcycles. You wanna talk about something else? Something bothering you other than the facts I have produced for you?
Your fantastic gsxr frontend is going to lower the front and leave you with an incorrect amount of trail already. Raising the rear will only make it worse.
Better to learn now than have a bike that's good for nothing.
@DohcBikes, again, sorry if that came across offensive, by no means was that the intent, I came here to pick brains and learn. This is exactly what I wanted to hear rather than "wrong" and "do it again". Wrong can mean a lot of things if you're not sure what's wrong other than what you thought might be wrong (tire clearance). Your last post is what I want to talk about. I'm happy to talk about something else somewhere else, but helping me see that rear trail being compounded is extremely helpful. Geometry isn't something I'm hugely versed on thus asking questions, here. Thanks. Sincerely, thanks. I'm attempting to learn now and this helps a lot.
There is no such thing as rear trail. Do yourself a favor and research the words 'motorcycle rake and trail'. I don't like to explain how things work but others here do and they will be along if you keep posting.
The reason I focused on the tire clearance is because it should be something that is easy to understand and if addressed correctly it automatically addresses the other areas I have mentioned.
Go way back and ask yourself WHY am i putting a gsxr front end on? WHY am i putting a flat thin seat on this bike? It's because you think it looks cool. That is not the most important thing about building a bike. Build it for actual improvement in every area and it will automatically look 'cool' because it will look functional.
Nobody said it would be easy. Oh wait, that's what everybody on the net says. This can be done if you do it right, but you should build a conventional custom first because you don't have the knowledge or background to do what you are proposing.
You wanna build that bike right research KZ superbikes, not hipster built bling bling on pipeburn.
Again, sorry if for some reason I stepped on your toes, typically people in forums are awesome resources to explain things so maybe we just got off on the wrong foot at the wrong time. Also, this is a first time custom build. Yes, I'm trying to do something that I think looks cool but yes, is a nice change from what is stock and what I found underperforming and extremely expensive to repair (stock rotors were OUTRAGEOUS to replace) and coming from a sport bike background just didn't feel awesome to ride in certain situations. I like the look of fork conversions but also like the performance i've had riding similar forks on other bikes. I know That may be a chicken before the egg way of thinking, but it's worth seeing what happens, especially in a learning process build.
As I've mentioned, I see the rear tire clearance issues you've mentioned. We knew it could be an issue but based on what was on the bike when we did the work we simply didn't know. I knew it wouldn't be an easy process at all, thus the reason for asking questions. Again, thanks for the help.
Also, let me know if it is more ideal to move this discussion to another build section than cafe racers (bob/chop or specials) in the case that it may not need to be here
You didn't affect me at all. I'm just talking about motorcycles.
The fact that a 33 year old motorcycle doesn't perform like a modern sport bike isn't going to change no matter how many parts you mismatch.
What makes you think forks from one bike will automatically make a completely different bike perform better?
There a whole bunch of questions I have asked you that you have not answered. They are not rhetorical questions, they are a way of getting you to think for yourself instead of handing you the answers. If you would actually attempt to answer some of the questions you have ignored I might be able to explain things further for you. I've obviously already explained more than you are willing to actually hear because you keep saying you need to learn but I already told you the facts. You don't just bolt parts together and call yourself a builder. Oh wait, that's what everyone on the net does. Then when it comes time for a ride report they disappear because it sucks to ride and they don't wnna admit it.
It's just math. All of it.
Who gives a crap where it's posted, it's just nomenclature. It's a custom bike. If you wanna be technical 97% of the bikes in the cafe forums are not even close to cafe racers and most have no idea what that really is and wouldn't build one if they did.
Again I appreciate everything you've said, and I know some trends including brat builts, etc. have built a mindset that in some eyes are ruining vintage bikes or are what people do if they don't know what they are doing. I'm not trying to resolve that conversation because of differing opinions of aesthetics and purpose. The triples in the photo were dropped the way they were to attempt to make up for the lowered rear which wasn't ideal at all. I'm aware of quite a few of your concerns and have researched frame re-enforcement from others that have tackled KZ fork conversions specifically and managed to properly support those increased loads for a weak frame as well as a noodle of a swing arm (there are plans to properly re-inforce). Some benefits are for looks. Some benefits are for improved performance. I've posed a lot of the same questions you have posed to others who have done conversions and things are positive and negative. Also, I am aware of ground clearance and it's a legitimate worry and one I'm looking into both in wheel size and potential lowered triple options. Honestly, All I'm attempting to do is build a unique bike. I have other bikes and enjoy riding those for different purposes. Performance for this project may not be perfect. If that falls within the 97% of people in cafe forums talking about builds then I'm ok with that (nomenclature or not). Again, a learning build is a learning build right?
You are contradicting yourself. So far you are decreasing ground clearance, ruining the geometry, forcing component interference, adding weight etc. and even after being told it is wrong you are hiding behind 'learning'. Well there you go you just learned it's built wrong already yet you are still trying to justify it. What you are doing is not unique a bunch of people are making the same mistakes and ignoring it.
You know if you want to stop addressing me and just start building and trying to prove me wrong I'm ready for that to happen any time. However if you continue to address me and my concerns I am going to continue to give you input. More than a few people want me to shut up already and let you run with It unchecked, trust me.
No problems here, let's just say happy new years and go have a drink or two and look forward to a year of working on bikes, whatever those may be. I don't de-value your opinion or your input in any way. If a bunch of people are making the same mistakes and ignoring it then I'm not the only one.
cheers to a happy new years. By my clock, i've got a solid hour and 9 minutes to burn.
