1982 Yamaha Virago XV750 FS - SW Michigan
Rich Ard
doin' the backstroke in an estrogen ocean
DTT BOTM WINNER
I have a titled, running XV750 for sale. This is not a beautiful bike - and I'd take pics but it's currently running off long fuel lines with the tank (couple of small dings) and seat (decent cover, but you're not going to use it anyway, right?) sitting in my cart. Bike has just shy of 30K miles, ~150psi compression in both cylinders, good stock exhaust, K&N air and oil filters; I just tore down the carbs, front brake (could use a new rotor; I have a spare that could probably be turned), and serviced the driveshaft. Brand new tires and battery, too.
Would be a good candidate if you're looking for something to cut up; you can start by redoing the wiring harness, which has been redone by PO to eliminate all relays, as well as the turn signals and horn. It has also been done entirely in red wire, which has been pretty entertaining.
I would like to see $600 out of this thing - I'm going to keep working on cleaning it up, but I would like to move it on out so I can work on a couple of other projects.
I have a thread going here if you're bored and want to see what red spaghetti looks like: http://viragotechforum.com/viewtopic.php?f=10&t=36520
Well never mind, then...here goes nothing. Haven't done this before, so it should be entertaining.
Plus I'm colorblind.
I haven't finished the control wiring but it runs! I am planning to put the 920 midnight trim on it and put it up for sale the next few weeks. Send me a PM if you want to talk.
