1983 CB750SC (Nighthawk) Build
TG21
Engineering Student Chasing a Dream Build
Hey all! I'm new to the forum here and recently purchased a 1983 CB750SC Nighthawk. Thought I'd start a build thread to document what I'm doing and as a way to help other spare time garage builds like mine if I can. I Purchased the bike for a fairly cheap price and it wasn't running at the time. Knew I would be inspecting the engine and rebuilding most likely so it didn't bother me. Anyways, here's what the bike looked like when I bought it:
Overall the bike was in good shape, all the electrics still worked, only missing a tank (stock tank is fugly anyways). Quickly began the teardown process.
The parts pile is getting pretty big in the corner of the garage. Hopefully it all goes back together smoothly :o
Put the engine on the bench and began teardown of that next.
Cams out:
Head off:
Cylinders Pulled:
Some Rust build up on cylinder 4 but was mainly surface rust from some water that managed to get in at some point. Came off with a quick wipe.
Next step for this weekend is to split the crankcase and have a look inside.
I've got a few questions about some things on the bike, but I'm going to do a quick search of the forums first. Just wanted to get this post up between classes.
If you've read this far then Thanks!
look forward to seeing what this turns into. I have a cb700sc with a spun rod bearing in pieces currently. Good luck!
Hopefully you can get that sorted out wahvtec.
Okay so I had a chance to continue teardown of the engine over the weekend.
The Rotor gave me some trouble since it was stuck on to the crank pretty good.
My local Honda dealer wanted $32 (Canadian) for the puller tool. Decided to take the risk and use my rear axle as the thread is the same. It worked and didn't ruin my rear axle bolt thankfully.
With the crankcases split I was able to have a look inside. The transmission and crank seem to be perfectly fine (This was a fairly low km bike with only 25,000km) Apart from replacing crank and conrod bearings, I'll need to replace a few seals but thats it.
Took the crank out and took off the conrods. I'll be media blasting the cases and the powder coating so it all has to come out anyways
I then removed the valves from the head (needed a break from the crankcase) however without a proper spring compressor it was far from a break. I managed to take the valves out but lets just say it was exhausting.
Next step is to get a closer look at bearing surfaces and start measuring tolerances to see what may need to be replaced. Some of the main bearings look like they may have spun and if thats the case I have bigger issues that I don't want to think about yet :o
Badum tiss
All it takes is a well placed socket and a good smack with a hammer. Do it in a clean controlled area, the head inside a tote works great, because otherwise you'll lose some keepers (which only matters if you're the type to re-use them :-\)
Are you planning to re-assemble the head yourself? In that case, gotta buy a spring compressor anyway.
DohcBikes said:
Badum tiss
Wow didn't even mean to do that but nice catch!
I used a magnetic rod in a socket and then pushed down on the socket. magnetic rod grabbed the keepers with no fuss.
I'll most likely be doing the valves myself and planning on buying a spring compressor. However I may need to buy a new head since my cylinder 4 had rust. Tossing around the option of buying cb900 barrels and head but unsure right now.
