1983 cb750sc not firing on outside cylinders
mg42gunner
Active Member
Title pretty much explains it. I went to fire up my bike this weekend and it wouldn't idle I put my hands on the exhaust pipes and my center two were warm but the outer two were still ice cold. Both cylinders are throwing out a nice blue spark but not firing any ideas?
And i have fuel at both carbs according to the drain screws at the bowls. It will idle on full choke and the center two pipes will heat up fairly quickly while the outsides remain cold.
Could also be stuck valves on the outside cylinders. How was the bike stored? gas at the float chamber does now mean gas vapor in the cylinders. have you cranked it for a while then pulleg the outside plugs? if thy are dry , then there is no gas getting from the bowl toe hte throat of the carbb,, could be a stuck needle float valve.
It was only stored for a winter, I drained the bowls and removed the tank because I needed to do some body work on it. I spun the motor until the carbs were dry.
Holy s#it I feel brainless, maybe it was just the irritation in the moment. But yes the plugs were completely dry... Looks like I'll be pulling the carbs...
Check your pilot jets, they tend to clog up very quick. And these are what you need at idle ,)
Verzonden vanaf mijn iPhone met behulp van Tapatalk
So how do I go about checking them? I pulled the jets out and it seems the pilot is way the hell in there and there isn't a notch in it for a screw driver... The pilot is the one under the plug correct?
i'm not sure how this is in the 83 carbs..... but they should be removable
The pilots in the 42ag carbs are pressed in and I haven't found a source for new ones to destroy my old ones to get them out.
Give them a good blast with carb cleaner in the bodies and hit them with compressed air a few times and see if you can ge the grud out without removing them. Pull all the removable parts out and covers etc to make sure you can rinse and blow the dirt out and not just move it from the pilots to another jet.
