1983 CM450 e Wiring issue PLEASE HELP!!
bastowp
Ok, I have a 1983 cm450e which has been stretched and hard tailed. In the process of altering the frame, I have stripped off the original wiring harness. I have recently acquired a motogadget m-unit and m-button to replace the wiring harness which does an amazing job of simplifying an cleaning the wiring up. OK. So the bike is wired up with the m-unit...headlight,front and rear turn signals, tail light, ignition switch, horn,start button....all seems good. I have the ignition system wired up as well....battery,coils,cdi,rectifier,starter solenoid all that stuff....and all seems to be correct. So heres my question...What am I supposed to do with the neutral overdrive switch wires? And what do I do with the oil pressure switch wire? i mean I know they eventually end up at a light bulb but am I supposed to tie them into anything first? I just don't know. Please help
Im using the motogadget mini speedo. But i can place those bulbs anywhere Id like.....Where do the 2 wires from the neutral/overdrive switch receive power from? Do i just splice into a positive cable somewhere> or are those wires already powered from an internal source? THANKS FOR THE REPLY !!!
Those wires should be switched ground. Run leads from a 10 amp fused positive to the bulbs and then run from the bulb to the switches/sending units.
AWESOME! I'm going to give it a go when I get into the shop again. Thanks for the reply! Ill post up a pic of the bike in its finished state soon. Really a nice classic looking bike.
