1985 Kawasaki zx550 GPz
stovee
Let Function Follow Form
About 2 months ago I saw an ad for a "Old Kawasaki Parts Bike" that caught my interest. I gave the guy a call and found that he wasn't really sure what he had, but it wasn't running and he wasn't sure how to fix it. Looking for a fun project to dive into I decided to go check the bike out. It turned out to be an 85 550 GPz, with matching numbers and only 19K miles on it. The guy was the second owner and the bike sat for about 15 years before he tried to get it going, unsuccessfully. Having brought some pretty haggard dirt bikes back to life, and looking at the great physical shape of the bike with some key new replacements, I decided to take the challenge and save it from decapitation.
The Bike: 85 GPz, 19K miles, Black
Original Parts: Engine, Carbs, Fairings, Tires (for real), Wheels, Suspension, ... pretty much everything
Newly Replaced Parts: Brakes, Exhaust, seat, fuse box, chain, battery
After I brought her home, it took me less than an hour before I had a million pieces spread out in my garage. The part I regret most is that in the excitement to find out what I had, I completely forgot to take a "before" picture. But some of the early shots I'll add will tell a nice story.
I gave her a proper physical, the verdict was that I had got myself a pretty sweet deal.
The Good:
- Frame is straight and sound
- Wheels are true
- Title is clean
The (not too) Bad:
- Carbs need a complete rebuild (nasty)
- Few faults in the wiring, probably a new voltage regulator needed
- Tires are shot (there freaking originals!)
- Rubbers need replaced (hand grips, pegs, assorted gaskets)
- Oil has some gas in it, related to the carb issue
- Front brake lever needs replaced (cracked)
- Some rust in the gas tank (needs cleaned and sealed)
- Some rust on the frame (needs cleaned and painted)
- Engine paint is flaking (looks like someone tried to rattle can it)
- Gas Cap is lose, and has no lock (the kid I got it from uses a filed bolt to jimmy it open)
- Tank was rattle caned black and has to tiny "I didn't prepare this for paint and might have rust" spots
- New seat has a couple slices in it
- The infamous "tank bracket" is gonzo (hard to find piece I need to find)
The ugly:
- Everything needs heavily cleaned, stripped, and painted (love this stuff)
- The engine? Who knows? Gatta fire her up and find out!
Chronological pics and write up on the way (I apologize in advance, my only working camera right now is on my phone). Below is what she looked like when she was new back in '85.
First Day
So the first day I took off all the cosmetics to take a good look at the frame and get an idea of what kind of shape the wiring was in. I took the carbs off and started them soaking, and started my inspections. Here she is in the inspection phase.
Def going with the old school 7" round up front (front fairing for sale)
All my parts organized by piles.... everywhere
The engine after a solid degrease bath
Pulled the Tank to prep it for sealing/stripping
Carbs
Onto rebuilding the carbs.
Took them all apart and laid em out, then soaked the bodies while I waited for the rebuild kits to come in. Check out the garbage gaskets, nasty.
Decided to start stripping some parts on the carb and other pieces. The carbs will look sick with a solid metal bottom piece and nicely painted black bodies and mixing cap.
Here's a test fit with the rebuild kit put into place.
I try and take my time with everything, but no bodies perfect. Check out the nice pregnant gasket I noticed after the test fit. Pulled it back off and redid the seal.
Paint Scheme
I'm getting ahead of myself, but here's my little 5 minute idea of what I'm thinking about doing with the paint. What do you guys think?
Neat little bikes those 550's - we had one in the wreckers I worked in as the shop runaround bike. Surprisingly nippy for little bike ;D
They had a tendency to wear out the primary chain - which was pretty expensive to replace so most of them ended up in the wreckers as parts.
Nice work so far - I think you might want to go for a slightly bigger tail to suit the tank. Just my 2c ;)
I have an '82 with a similar paint scheme for the most part. I'm still debating on whether or not to return the tank to the stock red or paint the side covers and tail fairing black. I painted the tank emblems red then hit the top with some fine paper on a DA. It put a cool pattern on it but kept a red outline which looks dang nifty against the black primer on the tank. My seat is also half red and the wheels are red. I think your bike will look good with a paint scheme like that.
