2-1 Exhaust Questions, Help!!!
jachana
I was playing in the garage today and started messing with my exhaust pipes. I welded them together as seen in pic. Then I made a 2-1 collector and added some pipe to that. I want to continue with the project by adding needed pipe to get it to the back where I can add a Dunstal muffler to it. my question is "Scientifically" will this setup work. Or do i need to have the collector further away from the head? Let me know what you guys think. Pipe is 1.5" coming out of the collector. Also there is about 8 inches from the head to the collector of pipe. I just want to make sure that that is enough or is it going to make the bike run crappy. I know I will have to rejet as well.
Bike is 1980 Honda CM400
Sorry about the crappy pics, just used my phone.
thanks
can't see the pictures... and scientifically, any exhaust will "work", it's just a matter of whether it will help the engine breathe better or worse than what was on there before. we need to know what bike it is too... that in some instances, has a minor impact on exhaust design.
Like stated above any will "work". What you have there looks neat. Might be hard to get those tubes out of the head with them welded solid right there, haha.
I think the head tubes are a little short for what works best for motor cycles. That would be a great header for a 2 cylinder tractor though. Meaning those short head tubes would be great for a torque building application. But, your little motor which works more off hp and revs than torque and low rpm grunt, would appreciate some more head tube length.
great info those are the answers I am looking for, I am new at exhaust building so for now I am just playing around. So then I should add some length before bringing them together. at the collector.
depends on the motor, was the 400 a 180 or 360 crank? if 360, then there is a good possibility of designing scavenging of one cylinder from the exhaust pulse of the other, but I think the primaries on that are so short as to have any usable impact in the rpm range of the motor. it might give you a good effect at 20k, but you'll be fishing pieces of conrods out of your shins before that happens :)
Oh crap, so that design just isnt a good one. I will add more length to the pipes and put the collector up under the motor like I have seen on this site on other bikes. Good news is with all the trial and ERROR is I already have a great collector made so I can scavenge that. Any other design ideas you guys have let me know, I will document this with lots of pics.
Ah good point, I didnt think about the angle going into the top of the collector. I can fix that easily. Any other suggestions or ideas please let me know, I want a very functional and racy setup!
If you wanna get really tricky, you can make the right exhaust header slightly longer and/or larger than the left so that you can get even spacing between the exhaust pulses. This will create a more efficient scavenging effect at higher RPM (provided your exhaust pipes aren't too large in diameter).
Because your bike uses a 180° firing instead of 360°, the cylinders fire one right after another and not opposite one another (did that make sense?). So what you're trying to do with the header design is to slow down the pulse from the second cylinder so that it hits the main portion of your exhaust pipe in the time in between pulses from your first cylinder.
Shorter primaries= low end power
Long primaries = Top end
you want something in the middle for a street application
Great info, Thanks for the help, I really appreciate you guys helping me on design. I know CM400's dont make the best cafe racers but I am trying to get it close and add some modern touches to it.
So I think I will run the pipes under the motor and then to the left side with a reverse cone muffler. The collector will located under the motor so hopefully I will have enough pipe length to be a nice working system.what do you guys think.
Could you post some pics of th exhaust when it's done and let us know what the total cost was when it was all done? I'm going to need a new exhaust for my CM and I am trying to figure out what's the best way to go. I know that Mac makes a 2-into-1 setup for about $280 bucks, but I don't like the muffler. I'd hate to have to spend another 60 bucks on top of that.
Thanks.
Oh yeah definitely, So Far here is my cost for the exhaust and projected total cost.
12ft of OD mild steel 1.5" tubing = $11
Gaskets = $8
U Bends (2) = $20
Muffler = $45
Heat rated paint = $15
Total = $99.00
So far so good on that cost. I will post pics when done.
