2 into 1 manifold for Carb
808shadow
Mechanical Engineering student at Texas Tech
Hi all,
I'm running the idea through my head of running 1 carb on my 75 cb200 project. I know the old harley's ran one carb and it worked just fine. My question is has anyone made this 2 into 1 manifold ? or can it be bought? Also I was wondering about the issues that could arise with such a layout. I am thinking about using a mikuni VM20 as the one carb. appreciate the info!
20 a little small I would think.
Most run into the issue of fitmemt around the frame.
Or the bigger question of why?
not feasible. It could physically be done, but the carb would then need a hole in the frame and that's never ideal.
well most cb200's I see use 2 vm20's, any larger is just a waste unless I'm going to bore, which I'm trying to avoid. I was just wondering if the manifold could be made cheaply and it could save me money overall so I wouldn't have to buy a second vm20. Again the vm20's are pretty consistant on these bikes when the stocks are being replaced. Room wouldn't be an issue. I'm not sure I understand what you mean by I would need a hole in the frame? If 2 can fit without any mods why would 1 not fit? I would have to maybe make a holding bracket but that can easily be done in CAD. Maybe I'm not understand correctly if you could explain a little more?
unless you mean for the tubes and wiring and such?Ah I think I see what your talking about now, the center bar being in the way I think, but couldnt I just put it slightly to one side and fix that problem? as long as the manifold has the same distance to each hole it shouldn't matter right?
By the time you're done with the time and money spent that fab, you could just go and buy a new set of carbs.
I hear ya but fortunately for me I have a friend that works for a company that would let me use their laser cutting machine on any scrap sheets they have and use their bending machines as well. And my university lets us use welding equipment as long you're in ASME or another engineering society which I am.
What Teazer is saying, is the frame has a huge boxy stamped steal post section. That would interfere with having one carb in the middle. And further back than stock...
So as an engineer (or least an engineer-to-be), the best solution you can come up with is to jury rig a single (too small) carb in place of what the engine was designed (by another engineer) to use?
Back to the drawing board, man. I think you could spending too much time with the "how" question and not enough time with "why".
Best solution no, like I said it was an idea. Plus I think it would obviously look cleaner. If you think what was designed and put into production was the first idea that came into an engineers head you are sorely mistaken. My goal would be to find the efficiency produced from stock and first see if it can be matched by a single Carb, which is a definite possibility to get it at least matched. Then I would come up with anywhere from 1-100 different possible ideas and work from the best of those to make a design. The sole purpose of this post was to see if someone else had gone through this process and found something that works. I could then use their experience to my advantage. Whether it means following what they did or improving upon a design. I don't mean to seem like I am attacking you but that is how i can best explain how my mind and engineering design works.
Sent from my PC36100 using Tapatalk 2
I think this would also add a unique look and honestly I love making things myself. Thank you guys for your input. I understand what you're saying.
I have thick skin, man. Don't worry about it.
The reason I point out the engineering principles is because I while away my forty hours a week as an engineer and that's how I tend to look at things.
First up, leave the looks to the marketing folks. This sort of engineering needs to put function ahead of form. The only reason I can think of to use a 2:1 manifold is cost. Individual carbs are superior in nearly every other way.
Unless your chambers have been CCed and you've rebuilt the engine, there's a pretty high likelihood that your two cylinders have different performance characteristics and feeding both of them from a single carb will not be ideal. With two carbs, you can tune around this (if needed).
As mentioned earlier, a manifold isn't likely to fit unless you run it off to one side. You then need to make sure the runners are not only equal in length, but flow the same. This gets increasingly difficult because of the lack of symmetry. Many vehicle manufacturers get around this through plenum design, but I suspect you don't want to go engineering a plenum (and it's not likely to fit, anyway).
Up next, we need to consider pumping losses. The more twists and turns your F/A mix is required to traverse translates directly into more work that needs to be done by your engine. This is an exponential function that roughly follows the RPMs of the engine. Keep things nice and straight and you reduce these losses.
I can only assume that you're strapped for cash and that's why you're looking to work around having only one working carb. If you're still set on going down that road, at least get a bigger carb. According to Mikuni, the VM20 is only good for between six and ten horsepower. At closer to 17 bhp from a CB200, you're going to want to go with a VM26. You're just wasting your time, otherwise.
Cool, I understand that a lot better! Yeah I'm strapped for cash but honestly maybe ill just have to go with 2. I just wanted to play with the idea of one. Thank you for the technical specs of it all, I can understand it best when explained that way! Since were on the topic of carbs would you guys reccomemd flat or round slides?
If cost is a concern, round slides will almost always be cheaper.
Flat slides are the option of choice for higher output engines, though. The "signal" (read: low pressure area) going across the jets is stronger and more immediate with flat slides. This creates a more responsive engine, which is especially important when modifications have been made to promote top end power (the reason being is that an increase in top end power usually comes with a decrease in low RPM output and so better throttle response is a very desirable trait).
If money is no concern, go with the flat slides as they will flow nominally better at high RPMs, too.
Gotcya, the round ones always seem to be sold out :( considering I'm leaving the engine stock I should be fine with round then, just gotta find em!
Also I would still love to see how this works in the old Harley's so if anyone finds links on the effeciency or diagrams of this please share!
What about a pair of stock Keihin carbs? Cheap , available and they work well enough. I'm a reformed engineer. I try to avoid doing engineering but sometimes I have a relapse and can't help myself. 2 carbs are more efficient than one as Sonrier explained. It is possible to make one optimized carb work as well as two stock carbs but that's not necessarily a good use of time or cash - two resources that there are never enough of.
As a pure engineering project, sure, go for it, but for running a bike as cheaply as possible, that isn't the optimal approach. I do that sort of sh*t all the time - because I can and because it's fun to do it and see the results. if you don't have a good set of stock carbs, shout out and I'm sure someone will have a set for the right price. I'm sure I have a couple of sets here somewhere.
BTW could you please fill in your profile so we have an idea where you are. Someone close may have what you need. :-)
Yeah ill update in the next hour or so. I'm studying for my thermodynamic test right now. While I love Texas Tech it puts me Northwest Texas, pretty isolated. Maybe I should start a thread for money saving ideas based on what I do and do not have. I appreciate all the comments guys
I've tried finding the stock for the 200 but they cost more on ebay than mekuni's. i found the Vm20's for anywhere from 65-80 a piece and the stocks are on ebay usually for like $180ish. figured even if they were the same cost I might as well go with something newer and unused.
