2 stroke triple pipe routing
Eric P
Active Member
I'm planning on rigging up a set of pipes for my suzuki triple at some point. I've seen some good (and not so good) pipe designs over the past few months.
My problem is that most of these pipes were off the bikes or at bad angles to see what's going on.
Does anyone have some pictures of how 2 stroke triple pipes are routed underneath? I need to figure out a way to keep some ground clearance and keep the pipes tucked up nice and tight underneath.
I've seen the TR750:
But unfortunately, I think that's a little out of my skill set.
I don't really care what brand or model the bike is. I just need some ideas and inspiration.
Thanks a "ton"! ;D
Peace
Eric
While I don't have a direct answer to your question (I haven't seen a lot of 2-stroke triples around or exhausts for them, for that matter), I will offer a piece of advice.
The pipes on a two-stroke are very important to the way the engine makes power. The wrong design or build (especially with the expansion chambers) will kill the power on your bike or move the torque curve to an unusable portion of your RPM range. Whoever you end up with as the maker of your exhaust, demand a dyno graph. If they don't have one available, that should be a litmus test as to whether or not to buy from them.
I'm planning on welding up my own pipes. I;m pretty sure I know what numbers I'm using, but they're pretty fat pipes. I just need to figure out how to bend them around the rest of the bike and keep some clearance too.
