2 wire regulator - please help the muppet.
Erskine
Over 1,000 Posts
Please throw me a line someone!!
So I have a honda based OHV CG125 engine in my bike.
I am running with no battery, no existing loom or other crap. Just a CDI ignition circuit out of the stator which runs perfect 100% sweet.
There are two more wires coming out of the stator, both are outputs but I've not connected them to anything. The stator is designed to produce all the power needed for an electric start road bike.
I want to run a brake light.
Later on I want to add in a headlight, tail light and the horn. Thats it. no ignition switch nothing else thats it.
At great bloody expense I have bought a regulator. Just two wires. Like this:
http://www.ooracing.com/store/index.php?act=viewProd&productId=3380
The stator is one of these:
http://www.petrolscooter.co.uk/stator-magneto-8-pole-cg-engine-125-150cc-quad-bike.html
How do I wire in the regulator?
Do I use both power leads?
If not do I have to do anything with the other one?
Does the regulator body need to be grounded?
Quite frankly I'm lost. All I want is some stable electricity. How hard can it be?
I'm allergic to electrical knowledge, have been all my life. When someone tries to explain it all to me I just mentally shut down. I'm quite happy to know very very little. However I am very good at following instructions.
And please don't ask any questions that require answers about numbers unless the answer is twelve.
The regulator will be between your hot wires out of the stator and your lights. Take your multimeter and find your hot wires. Twist them up to one of the regulator wires. Then test the other side of the regulator wire, it should read hot. If the body of the regulator has a charge then it needs to be grounded. Electrics are easy, you just need to think of them as on or off, hot or cold. If you dont have a multimeter then you can use a test lamp but i'd recommend a multimeter.
Hi Mate thanks for your reply ......... I've got a multi meter but it's a bit hit and miss whether I turn the dial to the right bit. However both the wires out of that bit of stator are 'hot'
The regulator I have ..... one wire defo is meant to go to earth, so that just leave one, which by looking at the schematic for a bike using the same engine, it shows a take off to accessories from the yellow wire before the regulator, implying that the regulator does not need to be 'in line' to regulate, it is just meant to be present and it will do it's funky thing ???
I have vague recollections of being told to just earth the second wire. Does any of this make sense?
Set your multimeter to AC 200v. Read the manual to see where the leads are plugged into. Black is usually com. Red I cant remember. Ground the black lead on bare metal, not plated or painted, all grounds should be clean bare metal, then touch the red to find hot wires. You should see 12v or 6v depending on the bike. Both the hot wires need to be regulated so tie them together onto the regulator lead.
The regulator should have voltage in, out, and a ground. If its only two wires then it could be grounded through the body.
Try this, twist both your hot wires onto the yellow wire. Then test the black wire for voltage. I bet it reads the same as the hot wires. Its probably grounded through the regulator body. Mount it where it will get some air, they can run hot.
You can build a really simple regulator/rectifier for about $10 at radio shack and they work just as good as any packaged item out there. They come with the added bonus of knowing what each piece is doing and how to fix it if it breaks. How are you going to fix that unit if it breaks other than replacing it?
I spoke to the outfit that I bought it from (ages ago) and dude said to do this:
One hot wire straight to earth.
Other hot wire to brake switch, back out from switch to brake light. before the brake light add regulator on a spur. Ground regulator body to chassis and black lead to earth. So that's what I'll try first. He said that it was better to have the reg only working when it was needed rather than in constant operation for no need. I don't understand why the body needs to be earthed as well as the black wire, but hey.
Hi, Thanks for all the input. The set up above ^^^ works and I have a good strong brake light even at tickover revs. Cheers all.
Hi PJ
The one intersecting the hot wire is yellow, the one to earth is black, also the regulator is earthed to the chassis as well.
Any idea what it came off?
If it's Honda, the black wire is battery voltage sensing, with only AC connection it won't 'know' battery voltage.
If you have a brake light you must have full lights, unless the MOT changed the law again?
I think it's a generic item, there's a link to it at the top of the thread. If the bulb blows then we'll know it doesn't work.
The impression I got when I mot'd it was it could either have a brake light or not.
I think it's a grey area up to interpretation by plod. MOT does NOT require a brake light, but highway law says you do.
I'm erring on the safe side. It's a fog lamp and very bright :)
I know when I was doing MOT's if you had brake light you had to have all lights working.
You were OK with just a reflector but some plod (you know Bridgend ) said that was part of lighting system and started handing out tickets >:(
Eventually magistrates told them to stop, except for the A**H*** magistrate who said you wouldn't be in court if you weren't guilty ::)
I wrote a few 'nice' letters back in the day when I worked for TWS 8)
I'd pretty much forgotten about all that shit until now
Thanks a bunch ;D ;D ;D (really LOL)
Brother PJ the black wire on an AC regulator is actually a ground that runs to the frame, the type of regulator that Brother Erskine referanced is very common on factory offroad ATV's and dirt bikes which run without a rectifier or battery. To wire this style of regulator you simply connect the yellow wire as a T connection in to the wire between the stator and headlight and connect the black wire to the frame, an AC regulator simply grounds out excess voltage to the frame. This type of regulator can only be used on a system without a rectifier or battery so if you were running one and decided to change to a battery system you would have to remove and replace the AC regulator with a regular rectifier to convert from AC to DC to charge the battery and run a regular street motorcycle style regulator as well. Most motorcycle guys are not very familiar with the AC regulators as they are more common to offroad equipment however they are very nice to use on custom applications when you want to run batteryless like Brother Erskines awesome build!
I've only ever fitted one AC regulator, on an XL185 that I removed battery and charging system then found I needed lights
It was around 1979~80, pretty much forgotten about it until I read your off road explanation
