2010 bikes complete
joea
Coast to Coast
DTT BOTM WINNER
Wow spectacular work! Classy rides. Bet the Ducati would look out of this world with a half fairing too.
i actually have the front fairing and all brackets done but like it better naked...
i'm in inver grove heights mn...i will add some detail shots and the list of items custom built......basically only work farmed out was the powdercoating and cad plating.....joe@vcycle
a little info...this is 66 narrow case 250 that i built though the fall/winter/spring . i bought two bikes for 800 and sold parts i did not need for about 900 so i actually got the bikes for free(like when that happens)...i still have enough to build one more machine which is about #3 on the build list.
custom parts in this photo ; front fender,brackets,modified bolt heads.
functional aluminum inlet scoop with s/s screen . drilled brake arm.
man, good job making all my work look like complete garbage!
EXCELLENT bikes! you seem crazy experienced... how long have you been at it?
rh aluminum side cover. .060 aluminum hammer and e/wheel formed and flanged with tool i made using an air nibbler. drilled and s/s screen added, side cover is held on by three brackets on each side using rivnuts and button hd screws. velocity stack is a modified unit off a amal concentric.
I absolutly love both of those bikes, but I cant stop looking at the honda. What type pf paint is that on the engine if you dont mind me asking?
-Ty
paint on the cb750 engine is a combination of wrinkle black powdercoat and gloss black high temp paint..
ducati custom photo; aluminum mirror, painted steel tubing headlight brackets and stays,gauge and brackets,alum gas cap,custom aircraft braided steel fuel lines...joe
my computer is f up so i will post a few a day ...sorry
shot of the headlight brackets,speedo ...
lh side with cover off...three brackets per side with rivnuts. battery strap aluminum ,inner fender is abs heat molded over a front fender.fuses clips were made so fuses assemblies can be removed with cover in place. org light is for charging.
tail light ; tractor supply reflector, took apart lengthwise(delaminated) and used aft sheet only. heat formed in oven and cut to fit hole made in tail section.
led tail light assembly; 20 white 3.3 v 25 ma bulbs with proper resistors(used a led calculator to figure all values) soldered on a circuit board then wired and mounted to the tail section.
