2stroke motor swap question
Doesn't much matter wether its a two stroke or four, size is usually the issue. What size two stroke are you looking at?
250cc I am not sure of make Its being looked into but it will be about 50 bux for the bike and it runs just has no wheels. The other option is an 85 xr 200 motor but it needs a full rebuild and would cost at least 200 for the bike and doesn't run
bradj said:
The honda will be the weakest link in that bike
He's right. The CB100 frame can only withstand so much punishment. Also, because its not a cradle frame, fitting another motor will be VERY difficult. The XR200 should bolt right in with little modification though...
I know the frame could be the fail point. So I will wait to see what the two stroke looks like. The downside with the 200 is the motors are stuck it seems that its the piston stuck but I cant be 100% sure so its a question of $$ to make it run at that point. The 200 swap is a popular one.
