350f rear wheels?
ninehudson
"leave the road, fallow the path" - MCD
just wondering what other model rear wheels i can fit on my '72 350f ?? got any ideas. i want to put a wider rim or tire from maybe a later model 500 or 750. could it work? any ideas or advice will help.
Ive tried a 71 450, and a comstar from a later 70's cb500.
Both will fit in your swing arm, but wont clear the slot for the axle.
sorry, I'm a bit challenged in these matters if I can't see a pic ;)
Not sure what you mean by 'won't clear the slot for the axle'?
thanks
ian
I think he means that the axle is too big to fit through the slot in the swingarm. Right?
I have a 120/80 r18 Avon Road Runner on the stock rear rim of my 350F. Fits great and looks WAY better than the stock tire size. Any bigger tire and I think I'd have to remove the chain guard. I THINK I may have had a 120/90 the tire before this, But I don't remember for sure.
Hope this helps.
BCB
Hope this helps.
BCB
may fit and LOOK great but it does nothing for handling and WILL wear out faster than a stock size tyre.
The rim is just too narrow for a tyre that big (WM2, 1.85") 120mm= 4.72", it's going to bulge over an inch each side
PJ
precisely.
This could be corrected if you know someone with a metal lathe. They could just mill off the area of the axle that need to slip into the swingarm.
PJ
So... Why? I wouldn't think it would do either of those things? What are the reasons for that? If that is the case... why don't/should all bikes have skinny ass tires like road bicycles?
Tyres are fitted to rims of varying widths.
Modern sport bikes with 180 tyre (about 7.1") use a 6"~7" wide rim.
The widest front usually fitted is a 120/70x17 on a 3.5" rim.
The rim width is measured on inside of flange where bead fits not on the outside edge.
If you fit oversize tyre to narrow rim it pinches beads together.
Tread has nowhere to go but upwards so you end up with LESS tread on the road when upright.
LESS tyre contact driving same power means it HAS to wear faster (which I have found to be the case even going up by 10mm oversize)
It will give more tyre contact when leaned over, but, you have to use higher pressure to prevent excessive sidewall flex (which causes even less tread to contact road when upright)
If your racing and can put up with the instability due to increased sidewall flex, it can be an advantage, particularly if rules won't allow wider rims (AHRMA lightweight, max rim WM3x18" to prevent 'modern' 17" tyres being used)
Here's link to pictures of WM1, WM2 and WM3 rims side by side for comparison.
Scroll to bottom of page
http://dotheton.com/index.php?topic=11736.105
I fitted a 90/90x18 on WM3 so sidewalls won't flex so much, means it will go where I 'point' it
PJ
So if YOU were doing a CB350K and were going to re-lace the wheels, would you bite the bullet and go for wm3's? or just paint/coat the existing rim and move on?
Where do you get wm3's?
If you checked link you'll see its my CB378.
I wouldn't even consider painting or powder coating stock rims
I already built several wheels with WM3 rims, flanged type for 'classic' cafe and smooth for 'racebike' plus, WM3 in pic is spare rim for 'dyno bike'
Rocan was asking similar questions about his 350 twin but he's using a 40 hole CB450 hub
Mikes XS has WM3x18 for XS650 which are 36 hole, flanged or 'smooth' for about $90.00 which is a real good deal (I paid $70.00 for used wheel to dismantle then spent at least 10~15 hrs making it 'pretty')
They will fit 250, 350 (twin and four), 360, 400f, etc.
Mikes rims wiil need spoke holes modified slightly for disc hub to change angle (few seconds with chainsaw file) but won't need any modification for drum rear hub
Ah. thanks for that. This could be solved by using the original axle, and swapping out the wheel bearings to ones with the right-sized ID.
Just another option I guess.
cheers
ian
No reason at all, I've done several over the years.
Biggest problem is finding a set that isnt too beat up.
You have to be careful with more modern rims as the 125 class used 32 hole instead of 36 hole ( I have a couple ::))
PJ
