Hello,
I recently picked up a 75' CB 360t. After doing some research I found there was a recall on the cam chain tensioner that could lead to some nasty side effects. I took the bike in and got the cam chain tensioner guides replaced with one from common motor collective (http://www.common-motor.com/honda-360-cam-chain-tensioner). When the mechanic did the switch, he said that it had looked like that same part had been installed, but that it had cracked in half. He said he went down with a magnet to check for any metal that may have been stuck, but said it was looking good. My question is: does this modification satisfy the recall? Also, should these be replaced every so often?
A side note now is that I'm learning there was a recall on the rocker arm. Does anyone know more information about this?
Thanks!
Thanks!
