50cc to 70cc question
Time for exhaust and headwork. The bike Joseph set that record with was not running at its best. . It is a good record to aim at. Once I have finnished moving my workshop we will play seriously with your bike
OK, stripped it back down and there's good news and bad news!
Good news is I haven't broken anything, or installed anything 'wrong'.
Bad news is ooracing sent the wrong head gasket with the kit. When I took it back if and laid it out with the old one its exactly the same size :(
So now I'm stuck until tuesday, when hopefully I'll receive the proper one.
IMG_6653 by sagalout, on Flickr
I just rebuilt the top end of my 50cc. Ported the head, unshrouded the valves, increased the valve pockets on the piston and removed the base gasket. Compression now 11:1. Huge difference! Easily gets to 73km/hr with a straight through muffler. I would keep the head gasket though. Unless you do a valve to piston clearance check (using putty) I think you may have a valve to piston clearance issue.
