Looking into grabbing one of these cheap EMGO coils for the XL to get it running. I know the deal with emgo parts, so spare me ;D.
and a new condenser from 4-into-1
The coil that came on the bike has a single prong in addition to the plug wire, same as the coil pictured above. It seems as though the wire (green) from the condenser and the B/W wire from the main switch are both soldered into that single prong. However the wiring diagram seems to show that there should be two outputs from the coil. On all the 12v coils i've used, there are always separate positive and negative terminals, as well as the plug wire.
Does this type of coil simply ground to the frame through the mounting bracket? That would make the most sense, as the single prong would then be the positive lead.
I'd think that the B/W should be wired through the condenser first via the female plug, and then the male plug would be routed into the single prong on the coil. The fact that on the old coil there is no order to the wiring is throwing me off.
Am I close here?
Am I close here?
