71 cb30, winter teardown performance suggestions/necessities
cabrito
ok, dropped the bike off with my buddy's shop and we are gonna give the motor a teardown for the winter. decided that since the left side head gasket is leaking a little and that side is smoking a little, might be a good idea. so, i'm looking for a list of stuff that needs to be done for sure as well some performance stuff. keep in mind i wanna keep it as stock as possible. here's what i've got so far:
NECESSARY:
gaskets
crank bearings
valve seals
cam timing (NEED MORE INFO HERE!!)
bosch coils
new points
clutch plates (probably)
POWER UPGRADES:
mikuni's (i have a side-door hook up to get a crazy deal but i will need suggestions based on the next two items)
polished ports
bored out??? (NEED SUGGESTIONS HERE!!)
custom 2-1 exhaust
OTHER NON-MOTOR ITEMS
cables
rebuild front forks
rear shocks
swing arm bushing
tires
i'm mostly looking for suggestions on getting a little more punch out of the motor. granted, i know it's a 350 but she's starting to get comfortable with the power and needs a little more on tap.
thanks
flynn
crank bearings don't exist from honda,if the crank is farked install another one,cb 350's don't have valve seals.cam timing,,DON'T touch,upgrade to yamaha xs360-400 coils (4 ohm) aftermarket clutch plates,cheap and will take a beating(don't ask) points are points..install a new set,,they don't have to be honda!......performance how much $$$$ do you want to spend??? the cheapest mod would be to install 66mm gpz 750 pistons,,or kz 440 pistons 67.5mm and the piston domes have to be machined(cut down the outside to clear the head casting...easy) if you really get serious it will cost $ 1200.00(and more)to build a fast motor, and you'll need 110 octane...hear last year it was $2.5 @litre........over bore your motor and it will go faster!,,,,or buy a bigger bike!!!!! WEE(todd)
