Got this guy last summer. Fixed it up on ht.net. Late last fall, a cam chain fail meant I had to tear it down again. Now, time for a cafe build, but no permanent mods - all modded parts are coming from a K4 complete parts bike that I may later restore.
Trying to make it look like a 'stock' cafe, as if Honda had turned these guys out in 71...
Thoughts?
First video is me trying to figure out what the engine noise was. Turned out to be a bad cam chain - exhaust valves were hitting the piston. Fortunately, I figured that out in time to save both the valves and the pistons. I'm still in college, so parts come in when I find spare cash. I also only get work done when I can make it to my parents house (they have graciously allowed me to use their garage ;D ).
I still need another seat pan so I can start on my new seat - the butt stop will be made of metal, with some upholstery. I wanted to retain the flip up seat. I also need to figure out exhaust... 2-1 or standard 2-2? If I do 2-1, I will likely route it below the engine and have a muffler under there. I don't have a way to bend pipe (though I can weld it) so I can't do an extravagant job.
Still have to finish up tank (fill holes, bondo, line it with some sort of liner and paint it)
Rear sets are made of two stock 350 shift levers, cut, welded and still in the process of being finished. I'm going to put a bearing in them and lengthen the stock passenger peg bolts so I can use both to keep the stock sort of theme. For a rear set job, they are going to be super cheap... if they work.
The green tape on the last picture is where my bum should end if I correctly position my junk right over the rear pegs. I heard this was the way to figure out rear set position and overall riding position (I'm 6' 3", so I know the bike looks kinda funny under me anyway)... am I right?
Thoughts?
