71 cb350 project "LL"
space pup
Active Member
hi,
tried to post and had it crash, so here is the quick version.
started to tinker on one of my 71 cb350s today, (i picked up 3 non functional ones last fall!) i plan on trying to cobble together 2 running bikes from the 3.
so today i started pokong away at the better of the bike. i put the carbs i cleaned back on, slapped the tank of the other bike on it, put a battery in it and kicked it over. after a few tries it, to my surprise, started!
it seems to be idling a bit fast and the right cylinder might be burning oil. probably worn piston rings. but at least it vrooms, so i am happy.
thats all for today.
oh and here are some pics of the two 71's the other is a '73 but its in parts, i scrapped the frame as it was completely rusted out
tinkered on the doppelganger of the running 350 today. i seem to be having an issue somewhere in the electrical system because i couldn't get a spark.
i thought maybe the high tension leads were worn or corroded and tried to take them off and quickly learned that they don't come off, but that was after i had already pulled one out :S
i had to do a makeshift repair to the ignition coil by drilling a hole in the plastic housing and re-solder the high tension wire back in and then filled it with epoxy putty.
so now i thin that maybe its the condesor unit that is no good. im not too sure though. might just be easier to replace the coils and the condenser all at once. not too sure what i am doing here, but i am learning a lot every time i poke around.
can anybody tell me a good place where i can get new coils and condenser units?
also tried to work on the running bike. quickly figured out the the right cylinder is not firing now. its still getting good compression and its sparking, so i think its an issue with the carb not delivering fuel effectively, but then again maybe not. im really just blundering my way through this with some occasional advice from my father.
don't think they exist... i believe your choices are used ones from your favourite online auction or aftermarket ones that you'll have to fiddle around to mount. i, and several other people on this site have successfully installed the coils you can buy from Mikesxs.net which are reasonably priced... the racers try and fit in the dynatek dc-3 coils which are spendy and bigger, but arguably better....
stock coils suck. get some from mikesxs or better yet spend the bread on the dynateks... your bike will run LOADS better with good coils.
