71 CL350 Electrical Issue - Please help troubleshoot
BungaloJoe
Hello everybody,
I rewired my 350 using the original connectors with all new wires. Also, I took off the turn signals, and added an old school chrome switch from DCC. I got everything put back together the way I thought it should be, but now I have a bit of an issue and cannot quite figure out the source:
There are two scenarios.
1. When the motor is not running.
When the motor is not running and I flip the ignition to the on position, everything functions perfectly.
-horn works.
-starter button works.
-with lights in the off position, all lights are off.
-switch to low beam and tail light and low beam turn on.
-switch to high beam and tail light and high beam turn on.
Again, everything functions as it should.
2. When the motor is running.
When I actually start the motor, things function differently.
-horn works.
-with the lights switched to the off position, the bike runs well and will continue running indefinitely. However, the high beam is on (even though the switch is in the off position), and tail light is off.
-while it is running, if I switch the lights to anything other than the off position, then the fuse blows.
Where is my short? Has anybody had a similar issue?
Any and all suggestions greatly appreciated! Thanks.
