71 Cl350- where to start?
tannerjellison
I recently bought a 1971 Cl350. Just the frame, engine, tank, forks, exhaust, and carbs. I want to get it to start and work from there. What do I need for bare minimum?
If you look up bare-bones wiring diagrams for the 350 you'll see the bare minimum it takes to run one.
I'm currently undergoing the same exercise. I had to break down my bike to move houses, so I'm putting it back together so I can evaluate the engine before starting in on the project.
I have the following on the bike:
  • forks, wheels, rear shocks (not necessary but make it easier to move around ;D
  • carbs and throttle (i.e. tube and cables)
  • battery
  • ignition: points or electronic, spark plugs, coils, condenser
  • fuel supply and hose
  • for the wiring you only need the basics. I've attached the diagram I believe Rich was referring to, but you can disregard the lights if you just want to get it running.
  • also, connect the right side handle bar control if you want to use the stock kill switch (unless you just bypass it)
  • ...and most importantly...the engine ;)
That's my favorite one, as it's pretty clear even if one isn't familiar with reading wiring diagrams.
