anthonylane
CL450 will hold idle a 1200 rpm and drive fine for a short distance before losing throttle response, and eventually cutting out.
I rode the bike 20 miles last Sunday, on and off the highway, putting different loads on her, and she ran great. She also ran great on my way into work Monday morning, but the ride home on Monday evening was a different story. Ran great 4 of the 5 miles, and started idle-surging, and cutting out the last mile. Pulled plugs and they were fuel-fouled. The gas is probably 2.5 weeks old (91 octane)
The PO mentioned the battery had a tendency to die, so that brings us to this Wednesday...
I picked up a battery tender, threw it on the battery Wednesday night, and all day yesterday until the "fully charged" light on the tender was on. I got home from work (Thursday) and decided I'd throw some new plugs in (B7ES), and take it for a test ride. The bike started up just fine, and I let it idle for 5 minutes (held at 1200 the whole time). I made approximately one city block and she started cutting out, and back firing, and finally died. I was able to get it started again and limped it home another block or two by keeping the revs up in first gear, anything below 3K and it wants to die.
I dropped the float bowls and didn't see anything unusual, probably an ounce of three week old gas in each.
I took a peak at the ignition and the points looked clean.
I re-checked comp. and both sides were within spec
What I know about the bike is this:
PO timed static ignition, cleaned and reassembled both carbs and cleaned the petcock. However, sold it to me with an intermittently non-firing right cylinder which was eventually fixed due to a loose float-needle. Spark was checked just after purchase and looked good.
Now my question is this:
Why would the bike want to idle just fine, drive well under load for a bit, and then cut out? Is it possible that the carbs have progressively gotten dirty or the float levels have changed since I purchased it earlier in the month? Is it possible that timing has some how gotten out of whack? Possible air-leaks happening on the intake boots? Battery is crap? Coils are crap? Intake valves too tight/loose?
I'm confused as to why the bike made a 15 mile ride home after purchasing, another 20 miles after fixing the stuck float, and now doesn't want to run well.
Hoping with your help, and some other resources I can nail the problem this weekend and be on the road Monday.
