71 T250 Lost All Electrics
TripleKing
After running aftermarket lights on the rear of my 71 T250, I painted and installed OEM turn signals. After installing my right rear signal, I had light to the right front, but none to the right rear. Thinking I had a bad light, I tried a test light which barely glowed and then I lost all electrics and I mean everything. No headlight, no spark nothing. I checked the fuse under the left side cover and it appears fine. Just to be sure, I directly connected the fuse wires and still nothing. There was no smoking, nothing. One minute I had power and the next I had nothing. What am I missing?
I used a test light on the rectifier, when I touch the power in to power out, it lights up, but jumping does not provide any power to the the bike.
Additional: I was checking the bullet connectors with the test light and when I hit one of the lines I had lights. So I buttoned it up and I had no electric. I then checked the bullet connectors again and boom, I had electric. Again, I buttoned things up. I had electric then I didn't. Now nothing will get the power back. Here is something funny: I connected the test light to positive batter terminal with the ignition off and the test light lights. I turn the key on and the light will not light off the positive battery terminal.
Short, rectifier? I don't know.
OK, I went and cleaned all connections and ground and still nothing. Then I played with the connection by the fuse and the lights would come on and if you moved the wire it would go out then come on and go off. Logically, I put all new wire and connections. Still behaved the same way. When I got the lights to come on, I left it on and the lights would dim until they went off. Now the won't come on and the battery is definitely good. The latest is that a problem I had yesterday has resurfaced.
I get power in the red wire from the rectifier to the fuse. When I turn the key to "on" the power to that wire (from the rectifier to the fuse) goes off. When I turn the key to off, the power comes back. I have power going to the key. I am thinking either ignition switch or rectifier. What is puzzling is that how turning the key on turns the power off from the rectifier to the fuse. I am thinking that either the rectifier diodes are working in reverse or the ignition switch is shorting. I am lost here.
