Harsh
I figured that since I lurk here enough that I might as well make a build thread. This isn't my first build and what I do certainly won't be ground breaking on this build, but hopefully you all will like it.
Since this build is for my daughter she will have some input into how things go. I am funding the build, but once it is all done she will get a loan from the bank and pay me back. She is young and purchasing a relatively inexpensive vehicle on a loan will allow her to make the payments and build her credit.
My 74 CB750.
My wife's 72 CB350.
Alright onto the good stuff.
So this is the starting platform. It didn't come with a title, but I have already rectified that with VA and I have a clean title in hand. The paint isn't nearly as good as it appears. The white stripes were painted by hand and in a lot of spots you can tell. The tank has been lined and the cross over tubes are clogged because of that. Not sure if there are pin holes or what, but I guess I will find out when I pour some MEK in the tank and go to town shaking the crap out of it.
I don't want to do spokes on this one. There is a guy that works next door to me that built a CB400A that needed some carb work done to one of his other bikes so I traded that along with some cash for a 78 CB400Tii front end, wheels, and swingarm (not sure if I can or will use that).
I picked up a dual piston front caliper and mounting bracket off of an 85 VT1100C for a bit better braking. I also bought a caliper off of an 83 VF750. The caliper is the same, but the mounting bracket is different. I will use whichever caliper is in better overall condition and the bracket off of the VT1100C.
85 VT
83 VF (right center)
I took both of the calipers apart to inspect, do a little bit of cleaning, and get an overall consensus of which one was in better condition. Neither caliper was in bad condition, but the 83 VF750 was just a tick better so that is the one I am going to use.
Everything mounted on the fork leg and the wheel mounted. The picture isn't at the best angle, but as far as I can tell I will not have to get a different rotor. Just like on the 750 I will send the rotor off to be ground flat and have some holes drilled in it.
My 74 CB750.
My wife's 72 CB350.
85 VT
