o2sensorheating
So like the title states, Ive spent days and weeks on this forum searching for my particular problem with no such luck for a solution.
Notes before my question:
- Good compression on both cylinders
- Brand new electonics including Sparck Moto harness, new antigravity 4cell, reg/rectifier, dyna 3ohm coils, condensor, new plugs and new wires.
- I own the clymer manual and saw no help for my problem
- Running velocity stacks and straight pipes
- Carbs rebuilt and running two needle spacers and 85/140 jets for each side
(diaghrams are good)
Ok so I got this bike running and driving about a month ago and it always had a problem breaking up at higher RPMs, so I supplemented that with more fuel (bigger jets) and the problem changed where the bike would basically shut itself off under load in a way that i deem could only be electrical and was running a capacitor at the time. My thought was that the capacitor was just not giving the plugs enough spark. So i swap out the OG coils and the capacitor for the dyna coils, new plug wires, new condensor, new plugs (gapped correctly), and a 4 cell antigravity battery. I checked spark on both sides and it looked good.
I try to crank the engine and i get nothing but a cough smoke occasionally out of the right side carb while kicking starting it and one back fire out of the left exhaust. So i then decide the timing must be way off, i pull the alternator cover off, replace and gap the points at .013 and have at it. With the ignition on and the test light on the left point and a ground, i see no light at all after multiple times rotating the engine with my wrench. To be sure i wasnt crazy, i tested the other point and did get a light (not where i wanted, but thats a part of the reason im down there).
What would cause a point not to get power regardless of where the crank is at? From what Ive provided, please help! I want this bike firing!
Thanks!!!
- Joe
Thanks!!!
- Joe
