whats up,
just picked up a cb550F from Cheavens. traded my cd175 for it.
brought it home and stripped it down. wiring was bad and the chrome was bad.
cleaned every thing up, and degreased it all, was going to pull the engine but had some seized bolts. so i decided to leave it in there. covered it and sanded and primed and painted the frame and swing arm. found that the swing arm bushings are no good, and the three seals on the engine for the shifter, clutch rod and gear shaft.
put on the clubmans, and wired in the controls. did a bunch of other things aswell.
at this time i new i needed a parts bike. so on the forum i found a 72 500F that partydog had, so i traded him my cm200t bobber. which was i good deal for me. because the tank on the inside is spotless and the covers are in great condition. got the wiring i needed and a few other
things that would of cost me.
any way, here are some pics as of now
so right now i am in the middle of doing the wiring, the frt end is off because i need fork seals,
and to clean up the forks and rim.
