72 Cb750 question for you fellers
theracedude
So, i have been working on the newest project. Its a 72 Cb750 frame with a 76 Cb750 engine. I removed the stock oil tank and installed a custom tank. Of course there is no oil in the engine or tank so i fill the tank, remove the spark plugs and start kicking it over to prime the system. Well i have been kicking for 20 minutes and still the oil has left the tank. WTF? is there some way to get oil in the engine in order to prime the pump? Thanks guys, Randy
I do not know if this is your problem or not, but it could be due to the location of the oil tank, the size lines and fittings used, or the orientation of the new tank and lines. I have not dealt with this issue first hand, but read a good bit about problems with the oil system on the 750's. Deviant1 has a 72 750 and we worked on it a ton to get it where it is. When he was thinking of relocating and possibly changing the oil reservoir, we researched and found many people had oil supply issues when doing the mod. We concluded that the stock system would just stay on his build.
pretty sure oil wont get to the head until theres pressure in the system, aka oil pump running WITH the motor.
your leg just wont cut it ;)
I agree! My frickin knee and my hemroids are about to blow out.
