72 CL175 Brake pedal
3cermak
Simple question; I'm stripping my 175 down to the frame and can't get the brake pedal off.
Looks to be simple, the arm should slide off the shaft right. Haven't been able to find any info on how to go about this but some pictures suggest there are two parts.
If I'm wrong set me straight. If nothing else can someone give me some pointers on where and how to persuade this thing to come off. I've tried just about everything short of cutting it off but nothing doing.
Cheers
I can't remember how I did it on my parts bike..... maybe soak it with aero-kroil and heat the brake lever?
Any close up pics handy?
I'm going to bump this one now that I have time to get back at it.
Heres some close up pics, hope this helps.
I think that the end of the shaft on the outer edge of the brake lever is slightly flared out. When you move the lever, does the shaft rotate with it?
The whole thing moves. Thats the issue, it won't just slide out. The lever and the shaft must be separate pieces, I just can't figure how to get them apart. With as long as this thing sat and was misused I can't rule out rust or bending.
I'd like to know if anyone has done this before and how exactly they went about it so I have a better starting place.
I'll try,,,,the shaft is fitted to the frame,brake lever installed,and the factory flares the shaft to prevent the brake lever from falling off,,,,,there thinking would be it would never have to be removed,,,,,,30 yrs later ;D
I Dunno... If I remember correctly my CL175 has a cotter pin setup, it's not flared. maybe a previous owner lost said pin and hammer on the piece until the pedal couldn't come off? I'll check tomorrow.
The brake lever is different on the sloper than the vertical motors. I should say, since the frames are different, the lever mounts are different.
But yeah LittleKip, the 68's is just a cotter pin and a washer. Easy as pie!
You could always weld a little extension on that bar, or, looking at the design, you could put the cotter pin on the inside... just make sure you leave enough metal after grinding that it still has something sticking through the far hole...
closer examination shows 2 cinch bolts(one missing)these clamp down the shaft to the frame?? is that shaft part of the centre stand assembly.If the brake lever is rotated and the shaft turns,the lever is seized to the shaft,,,,,,,I'm guessing!!!
i cant make sense of anything right now but one word is burning in my mind:
crowbar
but i'd get seriously happy with degreaser and clean the whole area up to see if it makes any sense. when i tore down my '80 honda, parts i thought were solid or cast badly often ended up being chrome parts, or literally a void that had been filled with so much crud, you wouldn't know a bolt was under there.
then whack it with penetrating oil and see if any ideas come along.
Todd's right, there is that cinch bolt. And it is also the same shaft used from the center stand.
When I got my parts bike, the frame was so rusted up that I basically cut that whole shaft out with no remorse. And that was after taking the bolts out.
3cermak, what's the chance of you getting rearsets and never using the original center stand? :D
That's what I'm doing on my 70' CB175.
Not such a silly idea !!!
Cheers.
