73 CB175 engine swap?
pat_00
First of all, great site! Second, sorry if this question has been asked a lot, I did search.
I just bought a 73 cb175 which is a great little bike. I will be doing some cafe-ish mods to it, once i get it roadworthy. I was wondering if I could upgrade to a larger engine, what ones from the CB series would fit? a 200 or 360?
Don't want to go nuts. I live in a hilly area, and a little more torque wouldn't go astray. Any suggestions?
Cheers.
I don't know how feasable it is to get anything significantly larger in there. You will run into clearance and mount location issues. I think the CB160-175-200 are all roughly the same engine. Maybe the 250 is too. The funny thing about all theses bikes is that the CB175 is not the biggest but makes the most HP out of all of them, so there is no benefit of switching to a 200-250 engine.
That said, probably the best route to go fast on a 175 is to shed some of the weight. If you want more grunt for driving around hills you can probably also get a front sprocket with one or 2 fewer teeth. This will of course affect your top speed and raise your cruising RPMs a bit. You can also do pod filters and a rejet, won't make the bike incredibly faster but if you do it right it will give you better throttle response.
It's not at all cost efficient to swap another engine in, you might as well pick up a bigger bike. You can get good money for a clean 175 and a GT380, RD350, XS400, GS400, GPZ550 and the likes go for pretty cheap. I may be wrong, but I also think engine swaps are much simpler in the Kawasaki KZ and Suzuki GS series bikes, since they share frame layouts, electrics ect. Most Honda bikes are custom built with their specific frames, electric and chassis bits.
Cheers,
Guy
[/quote]
Shedding weight is definately good advice...Over the winter my bike lost some weight and I lost about 30 lbs...It's amazing how much faster the bike is without having to haul my extra flab around...
