73 cb350 twin
redred5389
Active Member
hi i just bought a cb350 last year and slowly im turning it into a cafe racer. im looking to get new tires, seat and get a 2 into 1 exhaust. if you anyone has any recommendation on the tire sizes let me know. ooh and if any one can help me find a exhaust like chris fiaccone's bike. (last picture at the bottom)
this is what im working with....
On tires, the best advice is to usually stick to original stock sizes - they usually handle the best that way.
Chris fabricated that exhaust himself, out of stainless steel. That being said you could probably whip something similar up with a 2 into 1 header and aftermarket muffler. Lots of options out there.
So is the bike with the red springs etc. the way it is now?
i went w/ the 80 series 110 Bridgestone Battle Ax's on the back, stock size up front, brought the back end down about 3/8" and it's a little wider. No clearance problems with the chain or swing arm.
to:tim yes the bike still has red springs
i decided that i wanted to switch to a disc brake for the front. i was able to get everything but im having trouble finding the spokes for the front wheel. does any one know the size or lengths of the front spokes?
na it had nice dent on the side, with lil rust, so i compounded and sprayed it. :( im still thinking of what im gonna color it i was thinking of coloring it pink lol
im trying to take out the front bearing but it looks like it needs a special tool does anyone know what it is? or where i can get it?
finally took out those bearings!!! sent the wheel to powder coat. im selling this rim to get some money for my other stuff so if anyone know someone looking im taking offer right now, but definitely looking to sell it soon. 18in rim
questions on lacing
what happens if you do the opposite when lacing. you use the outer spokes as the inner and vice versa?
so about finished with my for wheel just not sure if the shop that true the wheel correctly. go to a different shop to get a second opinion. just not sure if those spokes should have so much thread.i feel like it could be aligned to one side more then the other
Who mounted and balanced the tire? They would have noticed if the wheel was off centre.
A local shop but what happen was when I went to pay the guy he told me only cash when i now he takes the card, and on top of that when I asked for a receipt he refused to give me one. Not nice guys at all. I not sure what to do? Go to another shop?
Is your tire on the rim backwards? check the rotation arrow on the side wall, the tread pattern looks backwards
go the wheels on and handle bar controls now the bike does idle unless i give it gas. i checked the carbs they seem good. going to check the valve clearance tomorrow
tried syncing the carbs today but it started raining and the connection i made to the manifold was leaking air
http://youtu.be/PduLFdqlB0M
