cafepenguin
Active Member
As the title says, I have a clutch problem with my 1973 Honda CB500
So, At first the clutch was somehow getting locked in engagement. I could shift through all the gears, but it would not let up so I could drive. I took the left side case off and checked, and everything seemed to be in order. I pulled the lifter rod out to inspect. Below are a couple pictures of it. Do these look right? The one thing I noticed is the grooves on the one side of the rod. Are those normal? Or could it be that they are causing the rod to get stuck. When I had the case off, I tried siding the rod in and out and it would catch a little. Or could it be the clutch plates are worn? I was going to pull the right case off, but the screws are too tight. I need to purchase an impact hammer, which I will be doing on Amazon tonight.
Second thing is, as I was riding, the shifter was giving me a lot of headache and catching and was very clunky. I would have to push real hard to get it to shift into gears? Again, is this a plate issue or possibly a rod issue? Any help that anyone might have would be very much appreciated. Thanks so much.
