73 cb500 engine removal question
GATOR
I'm trying to remove the engine and I have one bolt that won't budge. The bolt I'm referring to is the upper rear bolt. I removed the nut easily enough and the bolt itself will rotate, but it just won't slide out. I was thinking it might be that the engine resting on that bolt and the friction is keeping it from moving. I gently jacked the engine up ever so lightly just to relieve some pressure but it didn't make a difference. The engine will slide along the bolt a little but the bolt won't break free from the frame. Any help is greatly appreciated.
The bolt may be bent. Happens when folk dont know how to mount the motor properly. Order/buy a new one and cut that one out.
I ended up being able to get enough space in for a saw and cut the bolt. After cutting the bolt it slid out easily. The bold ended up being so pitted with rust that it wouldn't allow the spacer to slide over it. Thanks for the help.
If anyone has some suggestions where to find a 10mm x 270mm hex bolt I would greatly appreciate a heads up. So far I'm coming up dry.
