73' CL/CB450 throttle question
Derek4Real3
"pillow talk" 73' Honda CL450
what is used to get the throttle back to the idle postion? when i rev my throttle it sticks and i would like it to snap back to idle postion. Am i missing a spring or something?
Thanks
Have you lubed the springs? What about the cables? Are you running a dual cable throttle? I think the 450 needs the dual throttle system.
The se7en I built with the CB900RR motor needs a duel throttle cable. Obviously, in a car, this would be an awkward engineering feat (at best), so I put a heavy return spring to snap the throttle back into place. This might be straining on the wrist in a bike application but in my car, it doesn't make a difference.
--Chris
where are the springs to see if mine are still intact?
the cl450 is a single that splits between the two carbs, my cable is new.
on each side of the carbs, where the end of the cable is attached, it's spring loaded there, if that isn't the problem,take the tank off and check for kinks in the line, you might want to check the vacumn chambers on the carbs, i've had the same idle problems on my 450, there was residue on the inside surface,keeping the float from desending, i sanded with 400 grit paper and it idled fine after,
my cb200 is sticking as well. but only since i put the clubmans on and rebuilt the carbs. im thinking i may just need to put some grease in the throttle handle and some spray down the cables. any other reasons it doesn't return?
