73 CL350 engine part..
AzHonda
Coast to Coast
What is this penis thing sticking out? This is my first 350, I am familiar with the 360's and never ran into this part. My Clymers doesn't show what it is (its the 250-360cc version).
My question is. Can I take it off for polishing or will it foul something up? I almost want to say it is for the cam chain tensioner?
axeugene27 said:
350 has an automatic one you just loosen it and then tighten the lower nut.
Well take yours off and tell me what happens....lol I'll drive up to your neck of the woods and help you fix it if it screws things up. :)
Yes but it can only be done at a certain crank position.
just tighten it up and then take it off it wond damage anything. You just set it tight before you put it back on then loosen it ( at proper crank position) and let it spring back into place and then tighten it back up. That said polishing it seems a bit excessive.
Hand polish it on the bike with some 0000 steel wool and some rubbing compound, then clean it up with a fresh piece of 0000 steel wool that has no compound.
