crazypj
Split personality, I fake being smart
Re: '74 CB 360 Cafe Build - Boomerang
You didn't set tappets on overlap?
You will need to hold crank in correct position as the valve springs (plus magnets in generator) try to turn it out of position. I normally use a 14mm combination wrench on crank jammed against footrest or gearchange shaft (when you have rearsets fitted)
Basically, if you didn't have any trouble setting valves, you did it wrong ;D
