I guess I need some help brainstorming...
My cb125 will not run..
Backstory.. I bought this bike, cleaned the carb and it ran. I rode around a little bit than tore it down to chop it (it wasn't good enough condition to restore or anything like that) well that project drug out about 2 yrs like projects tend to do.. Now it's time to get it running.. Cleaned rebuilt carb, cleaned points again. Fired it up! Ran but felt like it needed some jetting due to exhaust and intake changes. Rode it about a mile.. Worse and worse... Pushed it back to the house. Checked battery, dead. Checked my wire found the charge wire loose. Fixed that, charged the battery. Will not run or even hit... Rechecked points, a little out, adjusted. Verified fire. Good. Got fuel. Checked valves, perfect. Carb perfect all jets clear. Getting plenty of fuel. Kick kick kick... Nothing. Check plug again, wet. Clean it. Check fire against, good. Won't hit.
What am I missing????
. It seems that if the battery doesn't have 6.5 or more volts IT WILL NOT START! it'll have spark but won't hit at all... O well.. I guess it's picky.. Are these bikes known for that?
