wcwmoto360
I had read a few thread about this and tried what was suggested with no luck. Just to recap, I removed the expansion ring clip and threaded a 6mm x 3" bolt into the center of the housing and bottomed it out on the shaft. Then I wrapped on the house with my rubber mallet and then began tightning the screw to pop the inner filter housing loose, but had no luck. In fact I think I stripped the treads trying to do this. I guess I will have to re-thread to 8mm and do something different. No I'm not trying to remove the whole housing, I know theirs a special nut holding it onto the gear shaft.
Are there any other suggestions for removing the filter housing?
Thanks in advance.
Thanks in advance.
